查看: 1839|回复: 0
[软件] Your Uninstaller! 2008 PRO v6.2.1340 多国语言版
17万
Lv.22 皇后
战狼!爱我中华!
759 小时
发表于 2008-12-20 08:30:30 | 显示全部楼层 |阅读模式 | 来自上海
        利用YourUninstaller!,你可以轻松查看到各种工具软件的卸载信息,根据卸载信息的提示,可以知道哪些程序可以被彻底地卸载;除了具有卸载功能外,该程序还具有启动程序管理功能,利用该功能你可以自定义各种需要随计算机系统一起启动的应用程序;此外,为方便你使用鼠标右键,该工具还新增了IE上下文菜单管理功能,利用这个功能你能提高计算机的操作效率。
                Your Uninstaller! uninstallersoftware is the industry's leading uninstaller software. It's theworld's 1st smart Drag&Uninstall™ uninstaller software under theWindows platform, works on all Windows versions including WindowsVista/XP/2000/ME/98/95/2003. It's as easy as using the recycle bin.Imagine! Just a drag-drop and the program you don't want will disappearfrom your computer-- as well as everything the unwanted program brings!Your Uninstaller! is a user-friendly way of removing unneededapplications on your computer. It can even remove some annoyingspywares!
Key features:
"[PRO]" means this feature is only available in Pro version of Your Uninstaller!.
* Completely remove any application installed.
* Deep scan of registry and entire disk for unused registry entries and files. [PRO]
* Remove programs that could not be removed by Add/Remove Program. [PRO]
* Uninstall screen savers. [PRO]
* Remove internet surfing traces. [PRO]
* Backup and restore registry.
* Registration key management.
* Built-in Disk Cleaner helps you find and remove unnecessary files on your disk to save space and make computer faster! [PRO]
* Built-in IE Context Menu Cleaner, cleans the context menu of Internet Explorer. [PRO]
* Built-in Startup Manager, take full control of Window startups. [PRO]
* Fix invalid desktop shortcuts and start menu shortcuts.
* Get the applications detail info even if it hide itself in deepdirectory, especially useful for finding out "Spy" applications. [PRO]
* Backup/restore installed-applications information.
* Uninstall with SINGLE drag-drop! Just drop a file on Your Uninstaller! icon on the desktop to see what happens! [PRO]
* List installed applications with appropriate icons(same as you see inthe Start Menu), you can easily find the application you want touninstall.
* Powerful search feature allows you quickly find the program you are about to uninstall.
* Automatic detection of invalid installations and removing them with one click.
* Force removal of uninstall related entries in the registry(care to use!). [PRO]
* Lighting speed at startup, 5-10 times faster than Add/Remove Program of Windows XP!
* Export programs list to file or printer.
* More ...
What's New in Your Uninstaller! 2008
Your Uninstaller! 2008 is a completly new release from previous versionwith redesigned scanning and processing method. Here's a brief newfeatures list:
* New Uninstall technology, removes program completely system wide.
* New Internet Traces Eraser, clear all your surfing traces, surf anonymously!
* New Rescue Center, restore your PC to any date, even a specified point.
* Windows Vista optimized for Microsoft's new system.
* Improved Advanced Uninstall to fix more problems.
* Improved UninstallWizard for both advanced users and common users.
* Improved Startup Manager, find more hidden programs.
* Improved Disk Cleaner, one click to clean. Scheduled clean.
* Improved user experience.
* Improved loading speed.
* Unicode support for all modules.
* Multiple language support. Now supports 12 languages.
* Cache support for fast access to all programs.
* Know more about each program installed on your computer.
* Improved deep system scan after uninstallation to find hidden registry entries.
* Load undocumented startup programs in Startup Manager, it's easy to find some spywares.
* Improved Disk Cleaner provides more options and faster speed.
* Improved Drag&Uninstall.
* More options added for advanced users.
* Other many minor improvements and changes.
官网:http://www.ursoftware.com
~Support Windows Vista/XP/2000/ME/98/95/2003~
Your Uninstaller! 2008 PRO v6.2 Build 1340 官方下载:
http://www.ursoftware.com/dlds/yu2008setup.exe
Your Uninstaller! 2008 PRO v6.2 Build 1342 Christmas Edition 官方下载:圣诞版~
http://www.ursoftware.com/dlds/yu2008setupxmas.exe
x:
http://w13.easy-share.com/1702736121.html
http://leehare.qupan.com/888005.html
http://www.uushare.com/user/leehare/file/1108445
http://www.brsbox.com/filebox/down/fc/795930b4e312b58179ef22264bd64e92
关于我们|电话:0574-65520000 ,GMT+8, 2025-2-25 03:39 , Processed in 0.081406 second(s), 21 queries , Apc On.
